Status
Not open for further replies.
1 - 2 of 2 Posts
I want to know the best way to hook up the 6000. I have a Sony VPL-VW10ht Projector. It will take Composite, S-video, and y/b/r/whatever. I know that the 6000 outputs VGA. I have a VGA cable with a 5/BNC breakout on the end to go into the PJ. Is this the best bet??
Also, If I output via VGA to my projector, can I use other outputs to go to my multiroom receiver. In the other rooms I have no need for HD. Is it a pain to switch outputs or are all outputs active?
Mike Flanagan
"If you want an Expensive Hobby, why don't you take up house repair!" ~ The Wife
1 - 2 of 2 Posts
Status
