I picked up some older (but nice) stereo equipment from a buddy at work. I had wanted a stereo strictly for music in my living room area (HT setup with surround sound etc. is upstairs) and got a decent deal on it. It's a 'surround sound' reciever from the early days with dolby 4 way surround, but I don't care much about that, it's switchable to just stereo on separate a/b channels, which is how I have it. I also have a nice EQ that came with it, and I'm just curious the best way to use it with the setup. The receiver has pre amp out/in for each speaker channel, which are tied together if no pre amp is used, so I just hooked the EQ in there which works well as it lets me monitor the volume as I turn it up and see the gain as the volume is increased. However, it won't work if/when I hook up the b channel speakers. The other option is to hook the EQ through the tape in/out and just hit tape monitor when I want the eq. This is nice as it will work for both speaker channels and if I don't want to use the eq I can just shut off tape monitor. However, it won't change with the volume.
So I guess the question is: Is running it through the pre amp in/out on the receiver any better than running it through the tape monitor or doesn't it matter?
