I am in the process of building a dedicated home theater and will be using a set of used Jamo D 6 speakers (5xLCR, 2xSUR and 2xSUB, plus 4 ceiling speakers).
The D 6LCR speakers are designed to be mounted to the wall. I plan to do this right below the projection screen. However, I have been unsuccessful in find a "best" way of doing this.
Option 1) Maximize stiffness of wall (cross studs, back plate of 3/4" plywood spanning all the studs, maybe even cross studs behind drywall), and mount speakers directly on the large plywood plate
Option 2) Try to "insulate" the speakers as much as possible. Mount speaker to matching size back panel of plywood, that is mounted to the studs using vibration absorbing grommets - i.e. each speaker is somewhat isolated
Or just not think about it and attach to simple backplate... It becomes a little hard to experiment due to the amount of work involved, though I will try. Suggestions?
Side note: I am planning for this wall to be double drywall probably using "green glue". I am not particular concerned about sound insulation, but the double drywall is easy to do and the green glue might help absorb some vibrations. If there is a "sound quality" reason to do it or not to do it, it would outweigh any other concerns
