I am reading about the issues with the DVI-HDMI black levels. I have an older Hitachi PJ-TX100 720p front projector with a DVI in. I have switched between the DVI in and component in and notice a slight diffference in black levels with the HD-A2 (v1.6 firmware).
What is the best way to test if I am getting the correct black levels? I have the standard dvd version of Digital DVD Essentials. Can I use that? Just use a simple plunge pattern?
Also, I have a setting in the projector's menu for the DVI that allows me to switch from "DVD" to "Computer." The "Computer" setting seems to brighten the image a bit. I kind of assume this may be a way to correct the black levels?
Thanks for your help,
Scott
Scott
