My room has a strong room mode(+12dB) around 90-100Hz. It is impractical to position main speakers/seating to truely minimize its effect.
What do you think the best/most realistic way would be to treat it?:
1)Cross the subwoofer over at 100Hz (as opposed to 80Hz or lower) and position the subwoofer appropriately (ie. in the width/length null spots for the mode). My concern is that the subwoofer bass will be directional at this high crossover.
2)Room treatments - obviously I will do as much as I reasonably can with room treatments but it just doesnt seem feasible to take off 9dB, even using bass traps specifically tuned to 100Hz. Can it be done without covering every single wall surface with panel traps?
3)EQ the main speakers/center channel. Obviously not the most desirable option.
Thoughts? Opinions?
Andy K.
Thoughts? Opinions?
Andy K.
