1 - 7 of 7 Posts
Will be used strictly as a pre/pro with separate amp... and used as a zone2 (but sound quality is not a big deal).
Which unit is a better pre/pro - mostly used for Home Theater.
thx!
805. It's worth the extra power, as long as you have the proper space to cool it. Better DACs, way more power.
As a pre/pro?
Well for Pre/Pro only usage, the newer pre/pro is ALWAYS the better Pre/Pro.
Only thing you lose with 806 is you get Audyssey MultiEQ instead of MultiEQ XT. You gain Dynamic EQ and Volume.
If you want full receiver, that's where the 805/806 debate comes in.
Just get the 806.
Sorry, long night for me....finals in 2 weeks...
But the 805 does have much better DACs (Burr Brown PCM1796), which are important if you're bitstreaming to the AVR...the $5,000 Yamaha RX-Z11 has the same DACs. Also better Audyssey ...
But for AVR, 805 is overall a better choice...IMO
Even if you dont bitstream to the receiver, and use LPCM, the same DAC's gets used.
1 - 7 of 7 Posts
