Hi all,
I'm currently using Monoprice (model 7607) for my side and rear channels but looking at replacing them with something much better.
Due to WAF, I can only use in walls and have read that BG Radia makes one of the best in walls and can get the PD-6LCri for a decent price.
Would these work well as surrounds even though they are meant for LCR?
Also, they are rated at 4 ohms, and I will be driving them wit my Anthem mrx-710 which does not specify it will run 4 ohms. Just wondering if you guys think I'll have any issues?
