Is the H100 sub signal sensing or does it have a hard on? Signal sensing can be annoying. I hate how a signal sensing sub can cut off during a movie, and the delay when it switches back on.
Originally Posted by Jakeman02 /forum/post/0
I know it has auto sensing I'm pretty sure it has an always on option also. Most subs do. I've never had a problem with auto sensing cutting off when it wasn't supposed to though. Usually just a notch or two raise in the subwoofer volume level on the receiver will send enough of a signal to keep it on if there is a problem.
What I'm wondering is if the sub will stay in standby mode and then if it will turn on when the receiver turns on.
Originally Posted by fronn /forum/post/0
There is a "hard on" and auto mode on the H-100. The Automode won't turn on until it's sent a strong enough signal (for example: if you have your receiver at a suitably low volume, the sub might not turn on even when bass is present, in my experience), it will not just turn on when the receiver is turned on either (unless you have an odd receiver that hits the bass a bit when turned on).
I haven't really had any trouble with the auto mode... I've had a few instances where I had to briefly turn up the volume to get the sub to turn on (the volume was pretty low at the time), but otherwise it's been fine -- I use the auto mode.
