Originally Posted by
atdamico /forum/post/0
Total BS. Show some data, any data, any study, anything at ALL that will support the fact that 170 w/ch is twice as loud as 100 w/ch. That is anything other than your ears. Once you provide the supporting documentation, then dialog can begin. Other than features, and with some exceptions, I defy you to tell the difference in a blind test, between a $500 and $1500 receiver.
That's a very simplistic take on things and i don't agree with it at all, having heard a large variety of equipment. One rule that I have learned is that audio equipment specs are completely meaningless and all you can do is trust your ears.
What I read from the above post is that the Z9 is in actual use twice as loud as a mid-tier 100 w/channel, and I believe it. Why? Because the Z9 isn't 170 watts per channel and mid-tier receivers aren't 100 watts per channel. The specs are completely bogus and tell you very little about real-world performance. As such, the "170 watts isn't twice as loud as 100 watts" statement has nothing to do with audio reproduction, it's just a statement of scientific fact within a vacuum of an environment. A 170 watt-rated amp can most certainly be twice as loud as a 100 watt-rated amp.
One reason that may explain the uselessness of RMS power specs is the fact that in actual listening, you don't listen permanently at those volumes. So what happens is that you listen at, say, 40 watts per channel. When you get to a portion of the CD/movie that has a huge dynamic leap, what you will hear will be your receiver's ability to react to large dynamic shifts and hit dynamic peaks that are much higher than rated specs. As such, who cares if it's 100 or 150 watts per channel RMS? I say this because in my 2-channel system, I am currently running a 70 watt per channel amp that seems to have more power reserves than my previous 120 watt per channel amp. And both of these amps tested over their rated specs by a similar amount. The 70 watter honestly seems more powerful and effortless than did the 120 watter, if that makes any sense. As such, the power ratings mean nothing to my ears. And with audio, there's nothing other than my ears! I can't hear "empirical proof".
The only time that watts per channel mean anything is when comparing different amps within a line. For example, the Bryston 4BST is more powerful than the 3BST. Compare it to a Krell, though, and you have to use your ears because the specs are not meaningful.
Anytime somebody asks for empirical proof of sonic superiority, it just seems ignorant to me. There is no such thing as sonic superiority since we all have different ears. That's why there's such a variety of different audio equipment out there - to match the huge variety of different types of sound that different people would like.
On to my opinion on the sonic differences between a $500 and a $1500 receiver. I think that there will be a difference, but that it's hard to determine in an AVR what is causing that improvement. It could be the added features that result in better processing, it could be the beefier power supplies, it could be lots of things. All I know is that it's completely subjective whether that difference is worth the money. Some will hear it clearly, some won't hear it at all.
It's different in the 2-channel audio world IMHO - in that realm, there is a HUGE difference between a $500 and a $1500 integrated amp and this discussion would not even be taking place.
