1 - 20 of 942 Posts
Big WMC guide changes starting 7/7
MOD NOTE: Continuation of this thread coinciding with MS' announcement of WMC guide sunset date is here: https://www.avsforum.com/forum/26-h...osing-guide-data-jan-2020-a.html#post58943370
M$ is switching guide data providers 7/7. Could be a little bumpy.
http://www.thegreenbutton.tv/forums/viewtopic.php?f=6&t=8903
I may go ahead and force an update and see how much damage is done so I don't have any surprises.
{crossing fingers, hoping for best}
I'm more optimistic. If they are changing over to whoever handles Xbox One guide data, then they would have an easier time continuing to provide it.
That universe of users is also larger, so I would think there would be less problems and ones that do pop up would be addressed much quicker.
Discussion Starter · #6 ·
Still using zap2it right now.
How can you tell? I think the screen that says, "guide provided by ..." will be incorrect unless the WMC app itself is replaced by a new version. I don't think that's ever going to happen. The log in task scheduler might show some clues. I'll watch it when I force an update and see if anything looks different.
I'm going to miss Zap2It. They've been very responsive over the years the few times I've had issues. But I suppose using the same provider they use for Xbox One would be better in the long term. Rovi is the guide for Dish and a couple of cable companies as well, so they should be accurate and reliable.
Discussion Starter · #8 · (Edited)
Well, my guide updated and appears to be fine. A little different, but no issues. About still shows Zap2It, but I see multiple schedules listed now where I only saw one before, and Guide Tool reset on its own.
EDIT: Others have reported the provider now says "Rovi". So it is indeed the same as Xbox One. I think that's a good sign. If there really are as few WMC users and MS says, maybe they won't mind keeping the guide data going indefinitely since the same provider does Xbox too.
Banned
I had no issues as well, and moving to Rovi is a GREAT thing for us. No need to stop providing it to us.
Premium Member
Man, I love my WMC in my bedroom. 65" right in front of my bed and connected to a PC where I can do almost anything and more and watch TV at any size I want. Use as much HD space as I wish, manage my shows how I want, $3 a month for the card vs crazy costs of standalone boxes that are sooo limited. Folks don't know what they are missing.
Back on topic, thanks for the info. I am glad we are not 100% forgotten yet.
Saw some odd behavior recording Tyrant on Tuesday night (two recordings but at different times and different lengths). I'll have to watch it to see if it recorded properly.
I don't know if this is a coincidence but my WMC lost its mind today for the first time since I started using it over 1.5 years ago and I was completely unaware of the guide changes.
As I said in this thread, WMC started putting my cable box on completely wrong channels today, for example entering 608 puts the box on 209, entering 664 puts it on 808, entering 754 puts it on 144.
I restarted my PC and cable box and the problem continued, I was able to solve it by going back through Setup TV Signal in WMC and it started working again.
Luckily I noticed the problem and was able to fix it between scheduled recordings so I shouldn't miss anything.
It's a total coincidence that I caught the problem in time because last night one channel was giving me a weak signal error, and it's only because I decided to test that channel again today that I caught the problem before recordings were ruined.
Would this be due to the guide changes or is it a coincidence? Has anyone else had this or a similar problem?
Banned
I forced a guide update yesterday, and everything seems to be working okay for the most part. The only thing odd I noticed is a few of my channel logos disappeared. I'm guessing there were some name changes, but should be easy enough to fix.
Hopefully it fixes the every few months you get down to one day of guide data issue....
thats my thought on it. especially if it is using the same source as the xbox one data (just speculating, but a good guess) since there is a very large population of xbox one users.
I have WMC on two PCs. The one that has a cable card switched to Rovi. The one with only OTA is still zap2it. It missed one day of updates, but updated today.
My guide data switched over but now I'm missing channels and without the Add Missing Channels option in WMC7 I can't fix it. I sent an email to Rovi Corp and hopefully they respond with a way we can help alleviate these issues.
Well, I did an update, and it was still Zap2It/Tribune, and re-ran TV setup because it was only giving me data until July 20. After re-running the setup, it switched to Rovi, and gave me data until July 25. No big changes other than changes to the name of some channels changed yet again, and not always for the better (History HD Canada on TMS was HISTHDC, now it's just HISHD...). But it works at least to the point where everything carried over seamlessly for me. Time will tell if Rovi's listings are better or worse. (I still have my TiVo, because WMC often fails to pick up "new to Canada" shows - e.g., History Canada often delays shows weeks/months between airing in the US and Canada. TiVo will pick up the episodes as new (first time shown in Canada), while WMC never did.) And plus for WMC to have some smarts in moving all my recordings over. I needed to do it anyways because a channel didn't update and since I never watched it, I never bothered fixing it.
I had to add these entries to my HOSTS file:
65.55.186.113 data.tvdownload.microsoft.com
72.246.56.59 cdn.epg.tvdownload.microsoft.com
Then perform a manual guide update and it did finally change to Rovi.
Thoughts on this Rovi change:
1. This isn't going to resolve the frequent MS guide outages. Because when the guide outages happen, it's never been the fault of Zap2it. Changing the source of the guide info has nothing to do with MS servers mysteriously failing occasionally. I predict we will still have the same sporadic MS guide outages.
2. This isn't going to solve the MS DNS issues. Obviously some IP's work for some people and some just don't and never will. HOST file mod's are still going to be needed for some users (like me).
3. This is clearly just another move by MS to save money.
1 - 20 of 942 Posts
