LIVE: AVSForum Tech Talk Podcast with Scott Wilkinson, Episode 5 Click here for details.
Enter to be our Home Theater of the Month Click here for details.
Originally Posted by Jim McC /t/1521229/bipoles-in-a-5-1-system#post_24449292
Thanks. And follow the same height and angle guidelines from Dolby?
Or should they be mounted on side walls directly across(90 degrees from my head)? If 90 degrees from my head, at what height?
The more I read, the more conflicting info I get.
bipoles should go behind the LP; dipoles go on the sides. In either configuration, surround speakers are typically supposed to be mounted 1-2 feet above ear height while seated as suggested in many setup guides.Quote:
Originally Posted by Jim McC /t/1521229/bipoles-in-a-5-1-system#post_24445915
When using Bipole surrounds in a 5.1 system, where is the ideal spot to mount them?
I have read side walls are best, and have also read rear wall is best.
I think he said the speakers are bipole. Second link address appropriate use of bi-pole speakers. Both links address suggested height surrounds.Quote:
Originally Posted by FMW /t/1521229/bipoles-in-a-5-1-system#post_24456792
Good. You finally completed the circle. Now the OP has both competing opinions.
