Hello,
For some reason I am unable to bitstream HD audio from my HPTC to my Denon 4520CI. When I play blu-rays with HD audio (DTS-MA or Dolby TrueHD) my receiver only shows "multi-channel in" as active (7 channels).
This also holds true for non-HD audio as Dolby Digital or DTS does not show either. Again, only multi-channel input for sound.
My setup:
HTPC to Denon 4520CI via HDMI (audio and video)
Intel H55 mobo with Core i3 (Intel drivers are all updated)
Win7 (again fully updated)
TMT5 (version .187)
Using MediaBrowser 3 with VCD to mount .iso files to play
Within Windows, I have activated the Intel HD audio (HDMI) as the default audio, disabled other sound devices, set the speaker output to 7 channels, and have tried seemingly every output format (e.g. 16 bit 44100, 24bit 44100, etc). In the window for the Denon (control panel, sound), it shows all supported formats such as DTS-MA, Dolby TrueHD, etc.
I've tried to figure out the problem for hours without any success. For some reason, this HTPC worked fine with my old Onkyo TX-NR905 but the Denon and the HTPC won't sync up.
Any idea what I should try to fix this issue?
TWells
My setup:
TMT5 (version .187)
TWells
