You can always use a black recessed outlet and just cut another hole for the HDMI Cables, or spray paint would do the trick too
Unfortunately that one requires a direct connection into power. I want a pass through outlet at the baseboard so I can plug it into my power conditioner.What about this one? https://www.homedepot.com/p/1-Gang-...W0-K-DiT-CxWuvc5phwPrhqgBLJiQ6t8aAosPEALw_wcB
Looks like you could modify the insert area for the cat5e and F connector to run your cables through.
Yeah I ordered a white one to paint. Was just hoping to find a black one so it looks better.You can always use a black recessed outlet and just cut another hole for the HDMI Cables, or spray paint would do the trick too
