I'm looking at getting a HDTV STB and I will most likely want to put the antenna in the attic (two-story house). According to antennaweb.org, all the HDTV stations I want to receive come from either 90 degrees or 107-110 degrees bearing. All the stations but one are no more than 30 miles away but the ABC affiliate is at least 50 miles away.
Anyone in the Blacksburg, VA (or Christiansburg, VA) have experience getting the HDTV signal from Roanoke, VA using an attic antenna? TitanTV.com recommended a Winegard Prostar 40" 15 element (7005A) amplified and directional antenna. However, the Platinum Series Winegard antennae look like a better product given that all the stations are so close in direction.
Also, is there anyone in the area (Blacksburg/Christiansburg, VA) that has an antenna installer that they would recommend? Here's the output from antennaweb.org (I've removed the analog stations and stations outside of my viewing area):
Digital Antenna Type Call Sign Channel Network City State Live Date Compass
Orientation
* yellow WBRA-DT 3 PBS Roanoke VA Mar 15 2003 109°
* yellow WFXR-DT 17 FOX Roanoke VA Jul 1 2003 109°
* yellow WDBJ-DT 18 CBS Roanoke VA Now Live 109°
* yellow WSLS-DT 30 NBC Roanoke VA Now Live 107°
* yellow WPXR-DT 36 PAX Roanoke VA Now Live 110°
* blue WJPR-DT 20 FOX Lynchburg VA Now Live 90°
* blue WSET-DT 34 ABC Lynchburg VA Jan 1 2004 90°
Peter
Orientation
Peter
