Over optical I think you can only get 2 channel PCM, so TrueHD (which you may only be getting the core part of...) is the better choice imho.
Originally Posted by elvisizer /forum/post/13757778
they should be the same, blu. there usually are slight differences in the overall volume level of the tracks, but once you set the relative volumes equally, you should not hear a difference between pcm and trueHD.
Originally Posted by bases1616 /forum/post/13760754
English Audio Formats for Spiderman 3
English PCM 5.1 Surround (48kHz/16-Bit/4.6mbps)
English Dolby TrueHD 5.1 Surround (48kHz/24-bit)
The DTHD will be the louder more fuller audio track on Spiderman 3. A good scene to test out is when Flint Marco becomes Sandman. The DTHD is definitely the more powerful audio track.
Originally Posted by jblank74 /forum/post/13760947
Do what I do, set it to Linear and on your receiver use Dolby Pro Logic IIx to distribute it to 5.1. At least on my Sony receiver, it makes an appreciable difference over using the regular bitstream for DTS and Dolby 5.1.
Originally Posted by Blu Camry SE /forum/post/13762746
My Panasonic Blu ray player is set to output TrueHD as decoded PCM, and sends that to my Onkyo receiver for multichannel processing...
Is this not the correct way of running things?![]()
Originally Posted by steven975 /forum/post/13763304
Don't forget the third English Track...Dolby Digital 5.1 at 640kbps.
The TrueHD and DD track are separate, and you can get one or the other. If you don't have HDMI, you are getting the DD track if the optical is set to Bitstream.
Contrary to what some have stated, there is no "core" Dolby Digital track inside the TrueHD track...it doesn't work like that. They are entirely separate, and which you get depends on your settings. I believe some menus actually change the track label, too.
Originally Posted by jblank74 /forum/post/13763560
If I am understanding you correctly, you are doing the exact thing I am doing.
Originally Posted by shadowrage /forum/post/13768251
The PCM sounds slightly more 'robust'. The TrueHD track is missing a certain something to where there is a difference that affects the listening experience, so small I can't identify it.(BTW I'm a sucker for bit depth and wanter to like the TrueHD more).
But with T5E I prefer the TrueHD to the PCM track. It doesn't matter which is better. Just choose what floats your boat.
Originally Posted by shadowrage /forum/post/13768282
DTS-MA.You're welcome.![]()
Go with the PCM, you won't second guess yourself.
