1181 - 1200 of 2128 Posts
I'm pretty sure now both come from the same transfer. The HDNet version just has untweaked colors and really cranked EE.
Hopefully someday we'll see a proper transfer from a 70mm source on optimal equipment. If Blade Runner can get the special treatment than surely 2001 can.
I agree 100%.
I suspect the transfer was made with the old 2K scanners, not with the new 4K ones used for Blade Runner.
Originally Posted by FrancescoP /forum/post/12552568
I agree 100%.
I suspect this as well. Very disappointing that the same studio would give the special treatment to Blade Runner but not to an equally great movie such as 2001.
So they can do the Extra Special Collectors Edition later that comes in a monolith case of course!
(and of course I probably buy it
No kidding!
Originally Posted by Kram Sacul /forum/post/12520201
A list of all the "loop filter free" titles would be interesting.
I only have a few bitstreams, but maybe xylon and/or benes would be interested in compiling a list. Here's the H.264 reference decoder with a patch to print the number of filtered pixels per frame.
http://www.w6rz.net/ldecod_loop.zip
Loop filter on:
Code:
Code:
C:\\video>ldecod -i bits0001.mpv
----------------------------- JM 13.0 (FRExt) -----------------------------
 Decoder config file                    : (null)
 Input H.264 bitstream                  : bits0001.mpv
 Output decoded YUV                     : test_dec.yuv
 Output status file                     : log.dec
 Input reference file                   : test_rec.yuv does not exist
                                          SNR values are not available
POC must = frame# or field# for SNRs to be correct
  Frame          POC  Pic#   QP    SnrY     SnrU     SnrV   Y:U:V Time(ms)
filtered luma pixels =   95455. edge =   45052, non-edge =   50403
00000(IDR)        0     0     6                             4:2:0     841
filtered luma pixels =   57969. edge =   29648, non-edge =   28321
00001( P )        3     1     5                             4:2:0     721
filtered luma pixels =   67582. edge =   39756, non-edge =   27826
00000( B )        1     2     6                             4:2:0     972
filtered luma pixels =   71551. edge =   43910, non-edge =   27641
00001( b )        2     3     7                             4:2:0     991
filtered luma pixels =   63311. edge =   32838, non-edge =   30473
00002( P )        5     3     6                             4:2:0    1472
filtered luma pixels =   63107. edge =   39988, non-edge =   23119
00002( b )        4     4     7                             4:2:0    1663
filtered luma pixels =   50439. edge =   26158, non-edge =   24281
Loop filter off:
Code:
Code:
C:\\xfer>ldecod -i bits0001.mpv
filtered luma pixels =       0. edge =       0, non-edge =       0
00000(IDR)        0     0    17                             4:2:0    1001
00001( P )        2     1    19                             4:2:0     852
00000( b )        1     2    21                             4:2:0    1201
00002( P )        4     2    18                             4:2:0     972
00001( b )        3     3    22                             4:2:0    1492
00003( P )        6     3    18                             4:2:0    1212
00002( b )        5     4    21                             4:2:0    1362
BTW, you can also use the reference decoder to check the levels of other decoding methods. The reference decoder is independent of video cards, rendering and other drivers.
You'll need a couple more tools to process the output of ldecod.
http://www.w6rz.net/clipyuvhd.zip
http://www.w6rz.net/yuvtorgb.zip
clipyuvhd splits the single 4:2:0 output file into individual 4:2:2 frames.
clipyuvhd 1920 1080 test_dec.yuv
yuvtorgb converts the 4:2:2 YUV files to a .tga file (that you can make a .png file from with Photoshop).
yuvtorgb 1920 1080 test0000.yuv test.tga
Ron
Originally Posted by benes /forum/post/12558986
Great. More work for me.
I'll add this to the list of things I check with new Blu-rays. And I'll slowly go back over old ones.
Is it sufficient to just scan a very small part of the file? Here is the beginning of POTC3 At World's End:
The reference decoder is pretty slow, so scanning the whole movie will be tedious. BTW, if you do scan the whole movie, you can disable writing to the output file with:
ldecod -i bits0001.mpv -o nul
I would test a few parts of the movie. At least some live footage (that is, not the very beginning with the studio stuff or the ending credits).
Ron
Originally Posted by benes /forum/post/12559044
Heres a scan of The Brothers Grimm Japanese HDDVD. I'm not sure if those errors make any difference. Its probably an issue with EvoDemux.
Code:
Code:
D:\\Downloads\\ldecod_loop>ldecod.exe -i e:\\PEVOB_MAIN_1.H.264.stream.0.avc
 Input H.264 bitstream                  : e:\\PEVOB_MAIN_1.H.264.stream.0.avc
read_new_slice: Found NALU_TYPE_FILL, len 2
Skipping these filling bits, proceeding w/ next NALU
00000(IDR)        0     0    24                             4:2:0     266
00001( P )        3     1    24                             4:2:0     234
00000( b )        1     2    24                             4:2:0     250
00001( b )        2     2    24                             4:2:0     234
00003( P )        6     2    24                             4:2:0     328
00002( b )        4     3    24                             4:2:0     360
00002( b )        5     3    24                             4:2:0     328
Those are not errors. It's just stuffing bytes. You will see that on Blu-ray streams also.
Ron
This may have been discussed before, but what is the cause of the streaking on the background in those last shots?
Looks like brushstrokes on the projected backgrounds doesn't it, Rob? Yes, there have been a fair number of comments on this in various threads.
I'd guess this is because the landscape in the background isn't real but projected/painted/printed on canvas or a wall or something else which wasn't perfectly plane when shooting this scenes ...
Kind of, but I have a hard time believing that they (Kubrick) would have let such a sloppy job slide by.
Originally Posted by msv /forum/post/12563364
I'd guess this because the landscape in the background isn't real but projected/painted/printed on canvas or a wall or something else which wasn't perfectly plane when shooting this scenes ...
This makes sense. I am guessing that the background was giving a weird type of reflection.
Whatever the cause, I think it is clearly not any kind of compression artifact, but instead something that is really there in the source material.
Oh, absolutely. I never meant to imply otherwise.
This is an example of the much better starfields, which I saw theatrically.
Happens a lot in space movies, the transfer will be great in live action scenes but the starfields will be muted.
