Hello,
I'm curious to find out if the RC1 can be programed. When using it with a Node 2i/N130 with fixed volume, on the remote remains some unused buttons which in case if programable can be used to control an amplifier. Here are the unused remote buttons when using an 2i or N130:
- On/Off
- Volume Up/Down
- The + and - which can be used to toggle the amp inputs
Asking because the rear end of RC1 is fitted with the same dark piece of plastic as on the front where the IR transmitter is.
But maybe just an design element...
