Putting together pics of before 14x14 room in basement that is now gutted to studs or foundation walls. Rough dimensions at this timd are 14.5 X 22.5X 8.3. i keep creeping on wifes extra bedroom She thinks we need in basement. She is giving up more now that she invisions hwr singing group rehearsing in there so the IB room and more s
pace is making more since to her.....selling the SIZZLE!!!!
. Doing entire 1500 sf bazement so working on other areas will give me break while making decsions or research....or when just outta funds to work on labor projects. My budget will be till funds are low, then rest and do little stuff. Ok, so wehave Finished gutting of media room. 1.5 xps foam board up on poured 8 inch poured concrete wall_ considering new load bearing wall for other long wall to add space and fix some structural issues. Also big expense and working on rooms to get ready for is moving hvac from attic(why it was put there is dumb) and moving to basement with ductwork for upstairs and seperate zone ducts for basement. Hopefully none of ir will have to go thru media room ans After lurking on avs couple months and other sites i have decided to do room in room build with decoupled ceiling sitting on walls of room in room. Might as well do it rigt as sound proof is something u dont want to go back and fix later...thanks to folks on this site who have taught me a lot. And inspired me ongoing way overboad to make this room awesome and making the dream much more rhan what it was initially after seeing what folks have done. By the way we are doing it all dyi. Might be? We hire help with but minimal if any.
T
T
