bondo doesn't have that long of a working time. you can use a little less hardener, but you have to be careful to not use to little.
In my experience, its best to just mix small amounts and deal with short working time...
Cause after you are done with a multiple batch patch job, you can always start sanding right after you get done patching. Just start sanding where you first started applying the bondo.
