My current Setup is as follows:
42 inch panasonic HDTV
ps3
xbox360
Pioneer D814-s
ED a2-300
My roomsize is small right now 11'6" x 15' 5", the floor is tile and the walls are cinder block for the most part so I know its not exactly a dream for acoustics but its what I have so I need to just deal with it for now (its a dorm room)...eventually I'll be moving it to a room most likely larger so I'd rather buy speakers that will be on the louder end for the size room that it is
My uses of the system at roughly 75% music 25%movies/tv....I'd like to get speakers that will be good especially for hip hop and rap...I don't necessarily need to spend a ton of money on audiophile quality but I don't want muddy speakers since I will use them for HT also....my budget is right around 200 probably but I could do as high as 300 if there seem to be better options that are worth it
ps3
xbox360
Pioneer D814-s
ED a2-300
