1 - 6 of 6 Posts
I've just been informed that I may need to focus my 5.1 speaker research on in-wall models. In fact I was asked to comment on the Bose Virtually Invisible speakers. I have no experience with these speakers.
How are they? Good choice for a 5.1 system? Is there something better I might want to look into? The budget is probably a little flexible.
In-walls that are potentially part of a timbre-matched 5.1 set from the same manufacturer would be the strong preference, especially if the option exists to use the same exact model for all 5.0 speakers.
Don't hold punches. I am not a brand name afficionado.
Put Bose in the search engine. All the comments about their speakers pretty much hold true to their in-walls as well
Checked out HTD.com, people seem to like those. Or if you have a higher budget look at Triad
Discussion Starter · #4 ·
Okay, thanks. Anyone else able to offer comments on HTD's speakers? I had been told to try to avoid speakers which use the wall itself as the speaker enclosure. Presumably it's a Bad Thing.
Yeah. I looked at those. Sadly, since this is just for non-primary listening (living room and bedroom), I doubt the budget would go as high as ~$2300 per set.
Home theater direct is FANTASTIC, I have set of the level two bookshelves and absolutely love them. Unfortunately it seems that only much higher priced in wall models seem to have their own dedicated enclosure. I am not an expert on in-walls, I do not own any nor have I ever extensively compared any. Best of luck though!
Originally Posted by PULLIAMM /forum/post/0
Nothing by Bose is ever recommended!
I guess the man never heard of the US military. Sounds like the man could coin the expression "Bose you" instead of "F.....you". I guess we mean that no one as smart or well informed would ever utter the name....again, forever,...from now till perpetuity...the end of the world as we know it......
1 - 6 of 6 Posts
