2201 - 2220 of 3380 Posts
Originally Posted by zieglj01 /forum/post/21404860
The CR C7 is the match
Interesting. Do you know if it's light enough to mount to a wall and if $89 is a good price for a used but good one?
Also, any opinions on the CR8s? I'm thinking of getting a pair for my bedroom and moving the CR67s to the Living room. I'm guessing they are bigger, but I'm having a hard time info on them. Anyone know there woofer size and dimensions?
The center has a key hole bracket on the back, and weighs around 11 lbs
The CR8 should have a 7" woofer. They are somewhere around 15 x 8 1/2 x 10 1/2
I'm guessing all the speakers in the CR line sound about the same. I've only read glowing reviews for the CR67. The CR7 is a 6" woofer I presume. Is the only difference between all these is the woofer size? I'm thinking the CR7 might look good to pick up for my 2.1 set up and forget the center. Add the CR67s to my LR surround.
Sorry, I thought the bigger the number, the bigger the woofer size. Not exactly true I guess. So the CR67 and CR7 have the same woofer size.
I have an old pair of CR5's that I want to use as rear surrounds and a CRC center speaker. What speakers in BA's current lineup with be a good match to serve as my mains? Thanks in advance for any advice.
Just wanted to share a shot of my vs260. Barely any user pictures on the web. I was concerned about the unique shape of the vs260 and how it would stay on my 6" x 6" speaker stand. It worked out very well at the end.
Well it is as I feared... looks like the floorstanders are sold out and have been removed from the Vanns site.
Looks like my VS set-up will be forever incomplete, knew I should have got them first, but I don't have room for them right now.
I just got my BA Classic CS2310 5.1 setup today. I use a Denon AVR-591 receiver.
Does anyone know what settings (crossover freq., etc.) I should tweak in the receiver?
The only info I found on one pro review said to change the sub's crossover to 80Hz, which I set in the receiver and on the sub itself.
Change it to 120 hz
Originally Posted by zieglj01 /forum/post/21419846
Change it to 120 hz
Ok done for the sub thru the receiver, but on the sub itself it only gives 40hz, 80hz and 180hz on the dial for choices.
Also, the speaker crossover freq. on the receiver is set to 80Hz. Should I change that as well?
Set the speakers to 120 - and the sub dial to 180
Originally Posted by zieglj01 /forum/post/21419943
Yes, and make sure the speakers are set to small
Thank you for the help. Much appreciated.
And about the sub's freq. dial being only able to do 40, 80 or 180. Does that matter what it's set at since the receiver is already at 120?
Put it on 180, for the fun of it
Can the VS260s hold their own in a 2.0 setup without a sub? What if I enjoy uplifting vocal trance? If they need a sub, which would you recommend?
The Boston has good strong bass for music - it may, or may not be
enough for you - for a musical sub, the VPS210
http://www.vanns.com/shop/servlet/it..._c=site_search
Bump.
I would think the current Classic Series II would be a good fit. It uses the same basic tweeter design and that is most important for matching speakers--to me anyway. It's the reason I felt comfortable with the VRC to go with my VR-Ms in my HT.
Check Ebay for the CR7 and CR9 speakers
http://www.ebay.com/sch/i.html?_from...All-Categories
