by the way, the seller said the sub still work the day he shipped it and he just mailed the original power cord today.
Originally Posted by juiceblrc /forum/post/12797191
I bought the BIC 100 & I had the same problem. No cord. They sent me a cord & then the amp was blowing fuses. I called them & they told me to send the amp back. It was defective & they sent me a new amp. Now it works great but, it was real incovenience ESPECIALLY SINCE I LIVE IN CANADA!!
Originally Posted by jetblack3s /forum/post/12796719
so i bought a used h100 sub on ebay and i arrived yesterday. i can't tell you how excited i was when i hurry home on my break from work and saw the sub sitting in my front door. anyway, i got it out the box and ****, no power cord.
i found a couple ac cord that would fit the sub and hooked it up. nothing, no power. so i checked the fuse, yup! **** is blown. i when to radio shack this morning to get 4 new fuses. got home, put in the first new fuse and doom! blown, the stand by light turn on for about half of a second and there goes my new fuse. so i change different cables, and tried cutting the ground tip on the male plug that goes in to the wall outlet. you guess it, my second fuse is blown. so i took the speaker and the rear panel off the box and check the connection, but they seems to be good, no burning smell or anything like that. put everyting back on and tried again, there goes my third and fourth fuse.
i am so xkdfei pissed right now, i just want to come home from a long work day to enjoy some movie, i been waiting for a long time to save up for this one. wtfuoiafakldf.... sorry.
so what do you guys think? do i have a bad amp, a short somewhere? maybe not the right power cord, since the stock one only have 2 tip coming out of the sub, instead of 3 on the cable. also, the seller told me that the cable is somewhat heavier than regular ac cables. what's your opinion on this? i serious need some help right now, i am going nuts as i am TYPING THIS. [email protected]#@##@$![]()
Originally Posted by sprtfan /forum/post/12800213
I was more than willing to do everything I could to help out and was going to ship a subwoofer cord along with the power cord since you needed one. I guess now we can wait and see what ebay wants to do about it now.
Originally Posted by mailiang /forum/post/12800384
Now I know why some people refer to them as Flea Bay.![]()
Ian![]()
Originally Posted by akavn /forum/post/12802245
I don't mean to offend, but are you sure the fuse is correctly rated for the amp? Perhaps the blown fuse it came with was a result of using the wrong fuse and if you bought the same rated fuse to replace it with it would blow too.
Originally Posted by jetblack3s /forum/post/12803092
I just bought like 10 more fuse, can I disconnect the sub from the amp to determine which part is faulty? If the fuse doesn't blow after I disconnect the sub from it, then there's a short between the wiring in the sub. Otherwise, it will be the amp. If it is the amp, then I can look more into it or just bring the amp to a professional, right
Originally Posted by sprtfan /forum/post/12804037
I never had to replace the fuse while I owned it. I'm not sure about this specific fuse or fuses in amps in general, but their can be two types of fuses at the same amperage. One is fast blow and the other is slow blow. It can be hard to tell the difference between the two sometimes. The fast blow might not work in this case if there is a spike in the amount of current the amp draws when it is first turned on. This spike would be less than 1 sec but could be enough for the fast blow fuse to go. The slow blow fuses would not blow. This might not have anything to do with this case, but could be a possabiltiy.
Originally Posted by jetblack3s /forum/post/12804264
just got home from work. before i put in another fuse, i decided to pull out the power board. one of the main capacitor is toasted. it reads "JIALON 200V" Cap. so you mean to tell me that this happen during the shipping?
the reason i didn't pay for insurance was, first, it seems like you are a trusted seller on ebay, second i never ever had any DOA in my past experience from buying something on ebay. please tell me what you are going to do about this. the sub is useless to me.
