Status
Not open for further replies.
1 - 2 of 2 Posts
I haven't tinkered with DVI inputs at all or with HTPC so you have to forgive my ignorant question. If my projector has VGA input and I use an adapter that goes from DVI to VGA to hook the cable from the Bravo 1 DVD player to my projector or would I still have to go through my PC?
Jason
Jason
Probably not if the adapter can properly convert the digital DVI signal to the analog VGA format.
1 - 2 of 2 Posts
Status
