Status
Not open for further replies.
1 - 5 of 5 Posts
Anyone been successful with either of these dvd / Display combinations?
If yes what adjustments to which box were required?
If no what did you try before you gave up?
I have this display with the Momitsu V880. It works really well through DVI - don't bother w/ the component output. From what I understand, the Bravo & Momitsu share internals to a large extent, so performance should be similar.
I have my PT50LC13 connected to the Samsung 931 via DVI and it looks great without any adjustments. It works on all resolutions (480p, 720p, and 1080i) without any image shift or snow. My Samsung 931 was manufactured 6/2003 so it has the latest firmware.
1 - 5 of 5 Posts
Status
