Hi all
First time poster.
I have a "bright" or "stuck" pixel toward the bottom right hand corner of my LE40A656. It's basically just one pixel which always glows white, no matter what the rest of the screen is showing.
It's clear from close up, and I've now convinced myself that I can see it against dark scenes from my normal viewing distance of 6 - 7 feet. Whether I actually can or not is another matter, but it's becoming an issue as instead of enjoying my set I sit through movies constantly looking at the corner to see if I can see it! Sad I know....
The set is four months old. The manual has some blurb about a few bright / dead pixels not constituting a fault, and not affecting performance. However, I don't agree - this was a mid to high end set when purchased, and I don't think it's acceptable.
So, what's people's views on this issue?
- Should I make a fuss with the retailer / Samsung?
- If either of them are willing to help, is there anything they can do to fix it short of replacing the screen?
- Is there anything I can do to sort the issue? I'd heard about computer programmes that rapidly flash changing colours?
Sorry for the long post, but views / guidance are appreciated!
T
First time poster.
T
