I was wondering if anyone here is using beyond Tv 3.5 and outputting it to a HDTV. I am running a 9800 pro and have a 34 inch widescreen sony HDTV with 4 component inputs and 1 hdmi input. I have a few questions!
When I output to my HDTV through component i have to set my screen resolution to 1920x1080 and i get a slight overscan, which is OK. I dont have a problem with BTV 3.5 but the problem i am having is when i try to play a file I have recorded previously or even when watching tv the screen is cropped on the sides showing me a 4:3 image. Is there a way to fix this do i need to encode it in a different resolution?
Also whenever i try to output a dvd through my radeon 9800 in beyond media (another program) i dont get any picture is this a harware or software issue. How would i fix this?
Thanks for any of you help you can provide,
Oh before i forget is it better to use the dvi to hdmi or use dvi to component adaptor to component cable to tv?
