1 - 7 of 7 Posts
· Registered
I've been looking for a cheap sound card to replace onboard sound.
My budget is between 20$ and 40$. Some available options are the Diamond cards and the Asus Xonar DG.
I need something with a variable crossover and subwoofer channel lowpass to send frequencies below 50hz or so to a subwoofer.
The subwoofer is diy and won't include a built in low pass filter so it is very important that the lfe channel be relatively free of mid bass content.
Thanks in advance
· Registered
Those sorts of choices and settings are often part of the driver or decoder software. I know for example that AC3 Filter can be used to remap channels and set levels.
1 - 7 of 7 Posts
