1 - 2 of 2 Posts
I need a budget 5.1 for a small room and I have narrowed down my choices to two setups. To fit within my budget I'm probably going to save the sub purchase for later when I can afford something decent for another $200-300.
1. Onkyo TX-SR608 Home Theater Receiver and Jamo S426HCS3 5pcs Home Theater Speaker System Bundle
http://www.tigerdirect.com/applicati...=ITD&body=MAIN
or
2. BIC bookshelves and center channel with Onkyo 308.
http://www.amazon.com/BIC-America-DV...2261939&sr=8-4
http://www.amazon.com/BIC-America-DV...2261939&sr=8-1
http://www.amazon.com/Onkyo-TX-SR308...2262042&sr=8-1
I can't find any reviews at all on the Jamo setup, the BICs seem to do well for their price point. I'm not expecting the world at my budget, I just need something decent for a small game/movie room. Which would you pick? Other options are welcomed!
I'm in the same boat as you. Trying to put together a "good" setup on a budget. My room is 15x15, windows on 3 walls, TV on the 4th. Only opening is a 30" doorway to another room. Not a huge room, so I'm not looking for a huge system.
Based on my reading here this is what I've narrowed my choices to:
-Denon AVR 590/1610 or 591/1611 receiver. I've read that the EQ program for the Denon is much better than the Onkyo, something I need for the small room I'm putting this into.
Pairing it with one of the following speaker options:
1-Jamo 7.0 "PJ" speakers (can't find any info on them-would be using them as 5.0) Found a set online for $120 shipped.
2-4 Jamo E805's for the satellites and the Jamo C400 center channel $260 for all 5 speakers
3-Polk RM6750 $165 shipped refurb'd by Polk.
If I go with 1 or 2 above I'd add the Lava LSP10 10" powered sub for $210.
The speakers are a huge price difference, $165 for a 5.1 boxed set to $330 for the PJ system with sub, to $470 for the Jamo pieced setup with sub. I'd imagine the $470 setup will be much better than the $165 setup, but I've read good things about the RM6750 too. Still on the fence.
Also, still need to narrow down which "budget" Blu-ray player to buy.
Too many choices, and varying opinions. I just need to pull the trigger on something.
1 - 2 of 2 Posts
