  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
Buffalo IR100 Issue
281 Views 0 Replies 1 Participant Last post by  12vman
After several Months of trouble-free performance, my IR Receiver/Sensor Stopped working in my Home Theater.
None of the Remotes(Receiver, DVD, VCR) work through the sensor but work fine when I point directly at the components.
The IR Sensor Flashes when I point any remote at it and press remote buttons.
Signal light on IR Receiver Block does not light up when sensor receives signal from remote. The signal Light on the IR Receiver briefly flashes when I unplug and plug in the AC Adapter.
I am very confused here since this has been working fine for 6 months now. I checked the connections at the Sensor and at the receiver, they look fine. The emitters are plugged into the receiver and are fastened to the individual components.
Am I missing something here?
Thanks in Advance,
-12vman
Status
Not open for further replies.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
Status
