Hi, long time lurker but first time poster.
I'm in North York, Toronto (properly pronounced Trawnna, y'see?). Six or seven years ago I lived on the 18th floor and got the full suite of Buffalo channels with one of those crummy square RCA indoor antennas but when I moved (much) closer to the ground I only got the basic CBC/CTV (sometimes) so went with cable.
After a protracted dispute with Rogers over their terrible service that never works and ever rising costs for less and less channels, I cut the cord (again) and put the antenna back up. None of the Buffalo channels came in and I didn't expect them to - but it got me Hockey Night in Canada so that's all I needed it for.
Then I got a new TV and re-scanned. And boom. WUTV came in. On the ground floor. Put it on the 2nd floor by a window, and WNED came in too, as did ION, but barely. Come to find out on here and rabbitears all about remapping, so I had been oblivious that everything had moved and just assumed they didn't come in at my new place. Re-scan on the top floor by a window also revealed new locations for local channels CITY-DT, CIII-DT, and the two OMNI networks.
Given the limitations of the RCA, I found a GE 32647 on surplus/clearance at Princess Auto for $12 and mounted it in my attic pointed exactly at the South Buffalo stations per my RabbitEars.info map. I've played with the alignment and angles and I pretty much have it in the best spot now.
I am using the amplifier from the old indoor RCA plastic square antenna, which is made out of RG59 not RG6. Without that, I only get the 8 CN Tower stations, but with the RCA amp, I get CHCH, CITS (though I seem to be getting a lot of multi path or something on RF14 as the signal is strong but will intermittently cut out to zero), WUTV, WNED, WPXJ, and 95% of the time WGRZ. WKBW is at best 50% of the time and WNLO/WIBV on RF36 is rare - maybe 20% of the time, if that.
My question is simple. I know this GE is junk - I paid $12 for it, after all. I also know I'm using the amplifier for an RCA indoor antenna which is probably not optimal. I love that I'm getting free TV for such little expense, but, seeking expert opinion here, how bad is this thing (pictured above), and how "not recommended" is using the amp from that old RCA?
If I am getting WKBW & WNLO/WIVB "sometimes" with this thing, with a good attic antenna (I am not able to go with an outdoor for various reasons I won't get into), and an actual proper amp, would I reasonably expect to get both? Its annoying not having CBS/CW & ABC reliably, but I don't want to outlay real cash if it's not going to help. Also what would the best bang for my buck be to try and improve these two channels?
Thank you!
