1 - 5 of 5 Posts
I'm in the process of building a HT 7.1 system, how would I go about wiring up my 2 back speakers for MONO? Everything else is to be stereo but from what I've been reading, the 2 back speakers in 7.1 need to be wired for MONO.
I know its a stupid question, but hell...I don't know how to do it!
Thanks in advance!
The 2 rear speakers (behind you) will play dual-mono or real stereo signals depending on the processing/decoding used. Just hook up each of the 7 speakers to their respective connections on your receiver and you're done. Make sure your speakers are laid out properly for 7.1 set-up (see attached diagram).
Good Luck,
Sanjay
Originally Posted by orangeblast /forum/post/0
so a mono signal is sent by the receiver and not done by the speakers?
Yes - if you choose a mono rear mode like DD - EX or DTS - ES. But why bother? Why not choose Dobly PL IIx and get stereo?
Ed
Thanks in advance!
What have you been reading that you got that impression? Perhaps you misunderstood what was being said?
1 - 5 of 5 Posts
