1 - 2 of 2 Posts
Has anyone actually built a dust filter to cover the air vents on a RP tv? My toshiba 52hmx85 is sucking in dust from the air vent, which is eventually making its way onto the screen. Even though the front portion of the tv is pretty much sealed off from the electronics that need to be cooled, there is some airflow to the front, which is carrying dust with it.
I vacuum regularly, so that doesn't seem to be the problem. I'm thinking of building a dust cover to try to keep some of the dust out. Here's a diagram showing the vent, as well as how I believe the dust is getting into the tv. Any similar experiences would be appreciated. I'm mostly looking for info on some mesh that will keep some dust out, while keeping the air flowing.
tv.doc 89.5k . file
1 - 2 of 2 Posts
