1 - 4 of 4 Posts
ok so my projector is view straight on the wall, no screen. I will be painting it on. im building a permanent frame on the wall according to the size of the image it projects.
now i will be getting a lens for it soon.
my question is, should i wait to get the lens before i build the frame?
if i build the frame, would i have trouble resizing when i get the lens?
Or build it for the eventual size you plan to project to...
Even when you get the lens (anamorphic, I assume), some of your material will be 16x9, correct? If you build the full size frame now, and mask it down to 16x9 size, you'll be good to go.
If you aren't sure what size your eventual 2.4:1 screen will be, I'm with BMinDC: wait.
1 - 4 of 4 Posts
