Any thoughts on building an Acoustic Door for a home theater?
Perhaps a fir frame (.75 thick (use 1x3s)) covered with high mass MDF (3/4 or 1"). Will have to route a channel in the long edges to accept a wood member for the hinge screws.
Fill cavities in frame between panels with fiberglass batting.
Q: Is green glue effective as glue? I.e., can I glue the MDF panels to the frame using green glue? Will this assist with damping/isolation. Otherwise I will have to screw each panel to the frame with green glue along the joints.
Anyone care to estimate STC?
What about same idea, but three layers! (perhaps use thinner MDF).
As the door gets thicker, will have to taper inwards (like a vault door) so it can operate. Maybe use multiple layers per above and a staggered door frame; just like a vault door.
Any other thoughts on how to attach two high mass panels separated by an air gap filled with damping material? (and still acheive function of a door - i.e., support its own weight when held by hinges along an edge.)
db
db
