I'm in the finish stage of my theater and family room. I have two Mid-Atlantic racks in the walls - a small one in the family room, and a gigantic one in the theater. I'd like to put custom faceplates on my gear, but the price from Mid-Atlantic is a bit outrageous - on the order of $100 per unit. I don't feel like spending $1000 for custom shelves, so I thought I'd buy some standard shelves and make some faceplates.
Has anyone done this? If so, what did you use? Which shelves? I assume you can't use the shelves with the front screws (like the U1-U4), but have to use the universal shelves (SH-5A) that screw onto the side rails, so you can put the separate faceplates on the front?
As for the faceplates themselves, I'm thinking that I'd make cardboard templates for each component, then transfer the template onto blank faceplates and cut the holes using a dremel tool. Other options are to make faceplates from black plastic or some other material.
Does anyone know the difference between the various faceplates? Some are 11-guage, some are 16 ga, some have different coatings. Anyone know which ones would be best for cutting holes in? I'm guessing the thinnest ones without the fancy coatings that could chip.
