Assuming that it is a supply outlet (air blows out of it when the system fan is on) you could either move it up higher in the wall, or locate a floor register in the new floor of the riser. The floor registers are narrower and made of heavier gauge metal. Either way, just try not to block the airflow with furniture, etc. My thoughts are that it would be simpler to just move it up higher on the wall.
