as usual....get a MUCH bigger power supply...i wouldnt get anything less than 700 watts personally just to be on the safe side...and yes id go with a full size case...Lian Li makes some nice ones!
Originally Posted by dpe8598 /forum/post/12938630
I would go with a 500 or 550 watt power supply, but here is the kicker, make sure it is actually 500 watts. People run into problems with power supplies, because they get crappy rippoffs that dont actually push out the specified power. Get a good quality one and you will be fine. Also, I would forget about quad core.
By the way, if your willing to settle for 720p resolution (which looks great on most TVs) you will be able to play crysis on all high settings and avg above 30fps with this rig.
Originally Posted by football76 /forum/post/12972749
About the video card- Save the $20-30 get the "stock" card, download nVidias software called nTune and manually set the clocks to "superclocked" speeds. I just did this exact process w/ my 8800 GTS 512.
