1 - 20 of 24 Posts
· Registered
Hello there I have an LG HDTV LCD 32" and I am a heavy duty PS3 player. One of the games that i usually play has a chess board with 9 fields printed like a mat on the screen, which never changes. The game is called Eye of Judgment for those who do not know it. I have these fields printed on my screen for several weeks now and the think is getting worse day by day. I simply cannot watch any movies because I have the stupid chessboard printed like an x-ray on my TV. I tried unplugging the TV, I tried leaving a white screen saver on for 3 nights (about 8 hours) and i tried jscreenfix prog. Nothing worked and i am really disappointed. What should i do and why does this persistence gets worse day by day?
· Registered
You should call up the manufacturer if its still under warranty because that's a defect.
· Registered
Originally Posted by duffman13 /forum/post/15532540
funny, i thought burn-in was a plasma-only issue. itneresting to hear LCD owners are affected by it too.
Well, burn-in can happen with normal old CRT TV's as well, but no one would argue that CRT TV's are plagued by IR issues and burn-in like Plasmas. I would say LCD TV's are close to CRT TV's when talking about susceptibility to IR and burn-in (i.e. it's very rare).
· Registered
Remind me to never buy an lg lcd...
· Registered
Here at work on our SCADA system the same image stays on screen for long periods of time...quite a bit of image retention...
· Registered
Originally Posted by NewOldVinyl /forum/post/15531840
Um, no. LCD is susceptible to image retention ("burn" if you prefer) and it is not a warranty-covered issue, especially in a case as extreme as this user is describing.
I'd think that LCD IR is a problem associated with defective or poor quality panels. I own a Sony and there is nothing in the documentation that says anything about permanent IR being a problem. Also, there is no mention of IR as user abuse and specifically excluded from the warranty.
The technology itself is not susceptible to burn in. If it was then it would be unsuitable for the hundreds of millions of computers and laptops that use LCDs to display static images for hours and hours on end.
· Registered
"Tonijo" could u pls post some pics to show us the burn in??
· Registered
I have seen IR/Burnin occur on a number of LCD monitors at work. And the brands range from Dell, HP, and Samsung. It does occur on LCD screens, it just takes considerably more effort and time to do. For instance these monitors had been left on 24/7 at the same login prompt for years.
· Registered
You also recall CRT being the dominion technology for many years before LCD took over?
· Registered
Ditto, and it's never been IR........it's always been burn in.
Plasma = IR, abuse & it can be burned in.
LCD = much harder to do but once done it's permanent, true burn in.
1 - 20 of 24 Posts
