Hello,
I am having a new home built in Dublin, CA (east bay area) that will be completed by ~Dec 2011. The home is built in a planned community (ie not custom) and so while I can tweak a few things, I cannot change key design aspects like room dimensions, windows, etc. The new house will have a rectangular room that I would like to purpose for a new home theater and has the following dimensions, 22'4" length x 11'11" width X 9' height.
I already own gear from my previous DIY theater .
My goal is to build a CIH set up but this time around, I'd like to get help in building it rather the DIY route. I've done a lot of lurking and reading on CIH set ups for several months now but am still far from being an expert.
From what I understand most, if not all, custom installers want you to buy their gear from the brands they carry so that they can "control the outcome." But I'd prefer to buy the gear on my own based on my own research (ie Prismasonic HD-6000RX, Seymour 120" or 130" 2.35, TBD front projector - maybe new Sony HW30 or Mits HC7800, Carada Masquerade CIH masking) to get the most bang for the dollar.
What I think I need help with (so far) is
1) Room acoustics consultation and implementation.
2) Recommendation of where to build a false wall given my speakers (Def Tech BP2000TL fronts ).
3) building the false wall
4) Installation of projector and Prismasonic lens and alignment.
5) Installation of 2.35 screen
6) Sound calibration
7) Integration of old and new components
It seems all folks here are DIY but again, I know my own limits and need help this time around. Is there an AVS affiliate in the west coast or perhaps custom installers who can help in my situation? Ideally, if I can find someone now, I could get advice on design and figure out what I should do before the dry wall is up and what I should do after.
Is a CEDIA certified installer recommended?
On a side note, the home builder has partnered with a local installer that does audio and security systems. But the scope & options are limited to select offerings. I was not interested in their 5.1/7.1 offerings since I have my own speakers but am interested in having the room pre-wired (HDMI, 16 gauge speaker cable and electrical outlet) for a front projector as well as surround speakers for a 7.1 set up since they can do it before the dry wall is put up. I figure this would be a safe and more economical option to pursue now rather than tearing up the walls or ceiling after the house is completely done to install cabling. Anyone disagree?
