Why not just disable hyperthreading?
Why not just disable hyperthreading? |
MyHD and AccessDTV work well together because both support file sharing unlike FusionHDTV. |
Originally posted by Chris White My Goal: Play one hi-def show while watching another, or, record two hi-def shows at the same time. Currently, I have an AccessDTV card in a 1 Ghz HTPC. I'm pretty sure it doesn't have enough CPU power to handle a second card, much less decode with software. To have enough power, I'd need another MOBO and CPU. So, my plan is to buy a second HDTV card and install it in separate PC that is on my LAN. |
So assuming the Access card and MyHD card will co-exist in the same system (I thought they didn't, but you might be using two computers) then I'd go with the MyHD card. |
Originally posted by Chris White Because I presume (foolishly I suspect) there are some advantages to having it. If the 2nd PC were to be used as an HTPC I would, but it's primarily used for other purposes. Thanks for chiming in here Cliff. As I recall, you have a 2nd card operating on a LAN. Let me see if I understand the implications of file sharing. The advantage of the file sharing is that I could, for example, watch a show using the ADTV that's currently being recorded by the MyHD. Conversely, if the Fusion is recording a show, the ADTV couldn't access it until it is complete. Correct? p.s. Who is Jim? |
Originally posted by Cliff Watson I don't think ADTV can read Fusion seq files. |
Originally posted by Chris White If the Fusion is using only 10% of the CPU for recording, then it should work satisfactorily alongside the AccessDTV in my system. I understand you just got the Fusion. My biggest concern is that you're having problems scheduling recordings. That's obviously a MUST HAVE for my intended use. |
Originally posted by Chris White Thanks again for all your advice Karyk. AcAccessDTV uses a separate guide completely so there would be no conflicts there. Two minor questions: Since I plan to use the Fusion for recording only (no playback), would I have to connect the sound card cable? Similarly, can I operate the program with a keyboard only and not connect the remote receiver? |
Originally posted by markthemapper I'm pretty sure the FusionHDTV card is the ONLY one that will coexist with my AccessDTV card. Is this statement true? |
