1 - 4 of 4 Posts
I am upgrading to an LCD from my current Sony WEGA KD30XS955 (a 30" 1080i widescreen CRT) I watch Movies and Sports all the time while playing Xbox 360 a bunch also if it makes a difference in TV selection. I've went to 4 stores in my area to check out what the TV's looked liked and noticed that each store had each TV set up different then the prior store. So it was aggrivating. I did narrow my choices to 4 TV's and did a lot of research and would like some opinions on these TV's, which you would buy and why or which you don't like and why. Any help is appreciated
Samsung 120hz LN46A650
Sharp Aquos 120hz LC-46D85U
Toshiba Regza 120hz 46XF550U
Mitsubishi 120hz LT-46148
All are great sets, the Samsung 650 gets the best reviews and is widely considered the best choice at it's price point. I've got the 630 version which is basically the same thing without the glossy screen and love it. If you weren't worried by reflections on your CRT then personally I think the 650 is the best choice.
1 - 4 of 4 Posts
