Jeff,
There are plenty of mail-order places to get cheaper cables. Here is just one to give you an idea of prices:
http://www.national-tech.com/cgi-bin...text=dvi+cable
Of the folks who have tried DVI vs Component, most generally do not see any (much) PQ difference between the two with an RP HDTV. DVI seems to make a difference with the DLP, RP LCD, and other digital displays though, so the type of HDTV you have can make a difference in the answer to your question.
I have a 65" Hitachi RP HDTV and I've toyed with getting a DVI cable too. I keep putting it off until someone comes along who says it makes a difference on an HDTV similar to mine. Then too, you need to make sure that the Comcast box you have supports DVI. Even if it has the connector, it make not have DVI enabled in the firmware.
