Cable Card Exrra Charges?
509 Views 3 Replies 4 Participants Last post by  chitchatjf
After a month a at a new house with 3 hd-dvr boxes I realized we did not use one particular tv much at all. I thought I would save some dough by switching from the $15 dvr box to a $2 cable card from TWC-Milwaukee. After scheduling and waiting for the guy to install he informs me that I will not get all my channels (i have showtime, hbo, cinamax, hd package etc). He wants to make sure that I know that. I tell him that is not what i think should happen. I was under the impression that i would get all the channels i get on the boxes, as you do not pay more for the each outlet, only the equipment you rent. He tells me that with cable card this is not the case. That it is all "a la carte" and to duplicate all of my channels on the cable card my bill will go way up. I told him to leave the box and forget the card. He made calls and checked with his supervisor that he was correct.
Is this right? You get charged more for channels on a cable card. The twc flier that has all the channelsand charges says nothing about this. It simply lists package prices and equipment costs...why wouldnt they tell me on the phone as I explained that I was switching to save money?
Status
Not open for further replies.
1 - 4 of 4 Posts
That really sucks!!
They should not be allowed to do that, if they want to charge the same as a STB that is one thing but what they are doing is a bad policy if you could do it I would tell them to come and get all of there boxes and tell them you are switching to satellite (even if it is a bluff you should get a response in your favor)!!
You do not have to pay extra for programming using a CableCard. You should be able to everything on a CableCard as you can using an STB.
Call and speak to the supervisor directly... or the supervisor's boss.
That is BS. The cable card not only allows one to see encrypted programming,it will also map it to trhe same channel desination as a box.
For example if you get ESPN-HD on ch 849 on the box,that is the channel you will recieve it on on the cable card set.
You cannot get ondemand or PPV with it however.
1 - 4 of 4 Posts
Status
