Need to purchase component video to 15pin RGB input on LT150. Does anyone know if Radio Shack makes this cable and if they do what the part number might be. If not, where can I purchase this at?
Also, I believe that I have read in earlier posts about breaking off certain pins on the RGB connection. Is this true for the LT150? Which ones would they be, and what would the purpose be?
Currently using a interlaced DVD player with component output but will more than likely purchase the RP56.
Thanks for your help,
Ken
Ken
