I am in the process of finishing the framing portion of my basement HT and want to create a central location for future upgrade of my current cable + 5 way splitter situation. Once completed, I plan to get Dish Network and I want access to satellite and local HDTV channels either via my DSS or UHF rooftop antenna. I also want the ability to distribute all signals to 5 locations in my home.
My basement is the only one slated for HDTV currently but an additional room may be upgraded later.
My question is: Where can I find the "network box" or "distribution panel" that I can install in my rough framing and then have access to all of the necessary hardware.....splitters, modulators, amplifiers etc... Does HD or Lowe's sell these type of access panels that could mount between studs that are 16"on center?
I want to achieve a professional appearance install on a do-it-yourselfers budget...If possible.
Any and all tips, links, info is appreciated.
Brett
Brett
