Status
Not open for further replies.
1 - 4 of 4 Posts
i just used a mono jack plug to rca and it works great.... mine is just a cheap one... not sure if quality makes a diff..
There was a lot a talk in this forum (search on sblive ) about voltage output and damaging receivers, it apparantly related to the sb live value I cards and specifically with denon receivers.
My card was a sblive DE 5.1 to a denon reciever... after a lot of research even a q to SB... i finally connected without any probs... best way is to search on name = shaun3 that should link you up to all relevant topics.
However, i cannot speak with any certainty about whether is an issue or not, and i don't want to send you down a path of worry like i went down before i bit the bullet and plugged in... but have a look and you decide.
1 - 4 of 4 Posts
Status
