Status
Not open for further replies.
1 - 6 of 6 Posts
· Registered
Seems as though the ground lifters we would use on cable to remove rolling lines and/or buzz from the system now also removes the ability for two-way communication between CATV home base and the box, thus rendering OnDemand control useless.
Anybody got any answers as to what to do???
· Registered
You just need to find a different ground lifter for this purpose. There are specific models for cable, satellite, etc. to accomodate the appropriate frequency bands.
Kal
· Registered
Discussion Starter · #3 ·
gone that route.
need to find a particular ground lift that allows for "return signal path". Along the lines of upstream cable modem. The problem is once you lift the ground, you lift the path of return.
· Registered
Yes but you only need to lift the ground at DC, not at the signal frequencies. I am using a Mondial on my cable line and communication works.
Kal
· Registered
Discussion Starter · #5 ·
I would assume you are using the MAGIC isolator?
1 - 6 of 6 Posts
Status
