What is the price on those 50 ft cables?
If the quality is there then it will be fine, The more copper the better.
If you wanted to make your own w/ rg6 you could.
A commonly recomended wire is the belden 1694a
found here for .42 a foot.
http://www.westlake-electronic.com/c...a&category=CAB
You would need to put your own ends on
http://www.westlake-electronic.com/c...&search_sent=1
If you do not have a crimper or a compression tool, then I would recomend you have them put the ends on.
Hope this helped.
Hope this helped.
