cable management?
411 Views 1 Reply 2 Participants Last post by  RandyWalters
i plan on putting my panasonic 42" plama above the fireplace and i really dont want to have to run wires inside the wall, id like to run them outside, but need something to cover them up. i have heard of some kind of plastic channel you can have the wires inside of and paint it but cant find anything. please help. thanks.
Status
Not open for further replies.
1 - 2 of 2 Posts
One good choice would be Wiremold 2300 series, or it's little brother 800. I don't know if you can paint it because it's semi-flexible plastic. Wiremold also makes a low profile metal raceway (2100 series) in gray or ivory (which is actually an off-white/alabaster color). 90 degree elbows are available for all three of these series.
Here's two other threads with good info:
http://www.avsforum.com/avs-vb/showt...=wiremold+2300
1 - 2 of 2 Posts
Status
